Hello everybody,
I'm a new user and have installed the Revit Architecture students verion on my computer. However, there are no templates or sample projects loaded with the program. Where can I get these kind of things.
See attached image (no file template is available)
Solved by DannyHubbard. Go to Solution.
Solved by scott_d_davis. Go to Solution.
Thanks Mr. Davis,
But do you mean I need to uninstall Revit and then reinstall it againg. Is that allowed by Autodesk.
Salem Abdalla
No need to uninstall.
Go to Control Panel
Choose Uninstall a Program
Select Autodesk Revit Architecure 2013
Choose Change
In the resulting dialog choose Add/Remove Features
Pick the content you want to download and install. Make sure you stay connected to the internet as the content is downloaded and depending on which content you choose to install and your internet speed this can take some time.
Danny
