Hi there,
I'm trying to work out if there's an option to orbit with the apple magic mouse in a 3d view. (usually it's middle click + shift). Is there a way I can add or change a keyboard shortcut to automatically make the mouse cursor the orbit tool?
I've made a shortcut to pan (shift+P) which works fine. I just can't find an option under the 'commands' that shows orbit. Unless it's under a different name?
Any help is appreciated.
Thanks.
i have same problem ..
horizontal scroling isnt working (natural geastrue)
The only way I have found to orbit around in 3-D is using the cube tool on the top right of the screen if you click an edge or face of the cube you can then orbit around but it's not great.... **** magic mouse!
