Really don't even need an API to do this. If you are looking to connect to
Map Guide, you can probably use exported DWG's. The exported object contain
the Revit information attached as xdata... Room boundaries are exportable
although not visible in Revit.
wrote in message news:4890693@discussion.autodesk.com...
I need to find and extract all nodes of every room and space together with
all properties included with these items.
This i to be able to recreate both the data externally, but most imporantly
the actual graphic representation of these elements in an external
application (like in MapGuide i.e.).
Is this possible with the current release of the API?
If not, when?
If so - where should I look for the syntax?
Best regards
