I think I sort of understand what you're asking for.
I must confess that I'm not really all that familiar with the Revit API,
nor that of the BAS which will be used in facility (do you happen to
know which one?).
I haven't seen this done before and I'm not sure which software packages
could help you out here. So, you're picturing a live, dynamically
updating model? (currently, the graphical aspects of our BAS are very
simple static images that simply have a field for readings to update in
each zone, this might be the easiest adaptation, having a good rendered
graphic here instead of the basic ones in use now)
I'm wondering if one of the "collaboration" packages might give you
something a little better to start with? Perhaps Navisworks?
http://www.autodesk.com/navisworks
Maybe even Vico55 Presenter?
http://www.vicosoftware.com/0/products/5d_presenter/features_and_benefits/tabid/84576/Default.aspx
Of course, they could be complete and total overkill and still require a
lot of customization as well...
I'd love to see something like what you are proposing in action, though.
How cool would that be. 😄
kinghorn4335 wrote:
> Thank you for your input.
> I have been doing what research I can and am learning that a direct approach to what I want is not there yet.
> Bare with me as I present a scenario and let me know if Im way off or maybe onto something and I apologize
> for my Revit ignorance I promise to be be more knowledgeable in the future as I learn Revit.
> (keep in mind, this client has money and is not looking for savings
> but alot of show of there systems)
> Could I construct the model of the existing facility and then render various views revealing different systems (i.e. HVAC)
> ( i see them brightly colored to show the routing throughout the ghosted or partially cut away building)
> And then on a computer screen next to this have the FM monitoring software showing their graphical representation
> of what the system is doing.
> Im not sure if I will ever be able to have the museum attendies be able to click on a system name from a list and then have
> both monitors update to that system view of the model and the FM information. But perhaps the musuem tour guide can
> show some examples, or there could be an identical list on each computer.....
> Further, what softwares would I need to create the model, and then animations of the each system highlighted as stated above
> and have the animation showing flow.....
> Am I explaining my vision very well or....
> Thanks
