I just downloaded VM fusion which is another parallel and I loaded windows 8.1 on my Mac 15" and when I went to download revit I am getting a connection timeout to the Autodesk download loaction.
Any help is appreciated I need to get this up and running I have Class deadlines to meet this week.
This has to be some sort of driver issue. I'm running it on Windows 8.1, but not with that hardware. And I don't imagine Apple is too worried about edge cases like ours to fix whatever is going on with those drivers and their hardware.
Apparently there is hope. If you shut down your weak video card (Intel hd 4000) the program seems to start up as normal, because of the fact that it can only work on the good video card. Don't ask me why it does this, my teacher came with this solution.
The negative side is, that your computer will use more energy, so when you're done using your program you should turn the weak card back on so the pc can choose again by itself.
