Once a completed designed floor space model has been loaded at one scale, then when expanding to a different scale (e.g. from 1:200 to 1:10) are the dimensions and floor area reliably unchanged in their process?
Revit Accuracy depends of your settings and not of scale.
In Manage > Project Units you can set the rounding of dimensions, that can be later override when needed.
I usualy, use some dimension styles with different settings and roundings.
For instance ,
Your Name
