Greetings,
I am rolling Revit 8.1 out to a few users via a network install.
The problem I am facing is that after the installation (done under administrator profile on Windows XP Pro PC's), when the user logs on, they do NOT see the start menu shortcuts for 8.1
Turns out that 2 problems seem to be creeping up.
1. The security permissions on the Docs and Settings/Autodesk/Autodesk Revit Building Systems 8.1 folder are for admin only, so I need to manually add access for the domain users.
2. On a couple PC's the short cuts have actually be placed in the Admin Start Menu folder, rather than All Users.
What is going on with this?
