But in Worksets, you should be working on a local copy, not the Central File
on the server. Speed should not be an issue in this case, because the
network only comes into play during STCs.
If Revit runs slow all the time, when opening/working on any file, including
the tutorial files, then something is wrong...typically a graphics issue.
Download the latest drivers for your graphics display from the computer
manufacturer, not the graphics card company.
Also, try contacting Support with your speed issues.
wrote in message news:4921719@discussion.autodesk.com...
Hi Tobin.
Where r u located.?
there is nothing wrong with your machine..even if you are using the dual
opteron SUN machine and gigabyte LAN connection and super fast IBM server,
the workset will slow down your work.. I have the same problem with the
workset. See how much "folder_backup" on your server revit has created for
you when u do STC (save to central). "8" does not help much either with this
matter, does it? Halo autodesk member..help please?...
