Hi All,
Does anyone know if Revit is able to produce a 3D PDF (U3D file) so that we do not need to have our clients install a viewer to view a small 3D model?
Thank you
Solved by LisaDrago. Go to Solution.
You know - I had this situation but unfortunately I was not able to produce it right from Revit - I had to use their competitor Bentleys plug-in to publish an I-model, which then opens up in Bentley View V81. From there you can publish to a 3d PDF.
Here is a link for the plug-in: http://www.bentley.com/en-US/Promo/Revit/i-model.htm
as much as I don't want put put a competitor up here - this was the only way I found to do it.
I have added some images below to help.
LD
not out of the box
you would have to go a 3rd party plug in for revit if there is one or go to another product entirely and export it out of there
DarrenP
Try out this app... great price and trial avilable; http://apps.exchange.autodesk.com/RVT/List/Search?productline=RVT&query=3D+PDF&facet=&collection=
Mike
You can also export a 3D view from Revit to a 3D DWF. It's better than a PDF in that it retains the information assigned to objects in the model, but since most people don't have Design Review (free download, free install), it's not as widely accepted.
I much better solution that I have found is a plugin by tetra4D. It’s freaking cool. I get a nice toolbar in Revit and it exports my colors and material very nice. Here’s a direct link to try it out.
JG
Edited by
Discussion_Admin
