revit 3013 - What can I do to solve a drafting pattern problem
2 REPLIES 2
andreia.mpcunha
893 Views, 2 Replies
This box with drafting patterns keep appearing, even after I cliked to accept the change for a new one ( to apply to a wall). It doesn't let me click in apply, and keep appearing over and over, until I click esc...
Can you please help me to solve this issue?
2 REPLIES 2
in reply to: andreia.mpcunha
So are you saying you are trying to import a .pat and it's not
going so good?
LisaDrago
Can you give a bit more information? What exactly are you doing and where? Are you working in the structure of the wall and changing the pattern of a material?
Images also help so we can see where you are.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
