So I download the trial for Revit 2015 and there are no libraries for floors or walls or any other elements. I google the problem and Revi replies that there is a problem with the system where you have to reload parts of the files but to understand the solution you have to be an expert in software which I am not. Oh yeah, I'm an expert in design, sorry. So I just wonder why revit sens out downloads which they know are defective and then expect you as the customer to fix them?
Solved by steveandrews1065. Go to Solution.
Solved by scott.a.green. Go to Solution.
Solved by Lineabove. Go to Solution.
SteveAndrews.
I am NOT an Autodesk Employee or have anything to do with Autodesk (except use their software for many years)
I take issue with your statement that Autodesk sends out Revit updates which they know are defective and then expect the customer to fix them.
Software is a work in progress.
Get over it or go back to a pencil.
AND...the content is a separate download.
You figure it out.
Everybody else has.
Steve,
Please see the following:
"Revit 2015: Templates and families not installed"
The content library was given a separate installer because sometimes during downloads there could be network interruptions that could cause some content such as the libraries to not be installed so we made that content a separate installation, this is not a defect, this was designed so that you wouldn't get a corrupted installation if you had a network error.
