Hi, I just recently purchased a Macbool Pro w/ retina display (mid 2014) with Intel Iris Graphics, I used bootcamp to install windows 8.1 and then dowloaded Revit 2015.
Revit is very flymsy, the size of the the graphics don't match, the banner tool doesn't show up unless I move my mouse over it and it freezes everytime I try to close something. Also my mouse will work on a view and then it won't work on another.
I was told that my video cards (Intel Iris) cannot support revit and that is why it is giving problems.
I have tried to read in different forums but all they mention is having Intel Iris Pro.
Is there anything I can do to solve this or will I have to return my mac?
Thank you!
It should work perfectly even with Intel Iris, I assume there must be something wrong with your settings, especially the Retina Display settings are often tricky.
Did you check this out? http://knowledge.autodesk.com/search-result/caas/sfdcarticles/sfdcarticles/Revit-User-interface-flic...
Cheers, Lejla
Thank you for your quick response!
Since Iris is pretty recently there really isn't a lot of info about how it would work with revit. I did change the settings like you said and it help... Revit began to work! But in the end I decided to return the computer since I shall be taking it abroad and will have to work solely on revit... not any other sofware so i guess I did not wanted to take any chances.
Thank you again!
