Revit 2015 on Windows 8.1 won't download
4 REPLIES 4
bengol1992
1125 Views, 4 Replies
Just partitioned my mac so I could run Windows 8.1 and finally be able to access Revit on my laptop. However, when I go to download Revit 2015 it hangs at 0 of 104mb downloaded and says less than 1 minute remaining. I have left the download for a number of hours and it still isn't moving. Any advice on how to fix this problem?
4 REPLIES 4
LisaDrago
in reply to: bengol1992
Hello - are you on subscription? I would go into the subscription center and request the media - you will find it on the left side of the page. Once you order it it will say it will take 3 weeks - i usually get it in 3 days.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
bengol1992
in reply to: LisaDrago
I have a student account so get the software for free, however it simply won't download. I left it for 8 hours yesterday but it never shifted from 0mb downloaded.
cbcarch
check your internet connection--can you download large files from other websites?
see if antivirus software or firewall is blocking download
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
DarrenP
in reply to: cbcarch
also try downloading from here:
You can access most current + previous supported version Browser Download links (including the Design & Creation Suites) through Matt, Autodesks Virtual Assistant. http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
>download links>Revit Products>Autodesk Revit
Please accept as a solution if this fully resolves the issue
DarrenP
