Hi!
Today I uninstalled Revit 2014 and installed 2015. When I try to start Revit 2015 I need to log in and import the license file.
When I do this I get the following error:
Import Request Failed
Issues which may have contributed to this error are listed. If you are not able to resolve the problem you should activate the license, rather than import it.
- No license has been exported from a source computer, or
- the product serial number on this computer does not match the product serial number on the source computer, or
- the license is reserved under a different Login ID and password. (41)
Click the "Try Again" link to resubmit the request. If the problem persists, you should activate the license, rather than import it. Try again Error reference:41
I tried to find a solution online, but didn't find anything.
How do I fix this?
hi, maybe you try to check it here. thanks
http://knowledge.autodesk.com/customer-service/installation-activation-licensing/activate-register
hi, so we can close the issue and move on and mark as solution.
