Revit 2014
2 REPLIES 2
ennujozlagam
713 Views, 2 Replies
Revit 2014
Hi Guys,
Maybe you could help me with this. When i load my column it follow wall hatching. How im going to remove the hatching from my column.
Please see attached.
Thank you
2 REPLIES 2
LisaDrago
in reply to: ennujozlagam
Hello - I did a little looking and the only way I found for the wall pattern not to cover the column was to change the column family - I unchecked the Automatically joins geometry to walls. Image attached
Now this does prevent from it joining and will give you lines for the column even if you embed it in the wall - so this may not be the best option...
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
ennujozlagam
in reply to: LisaDrago
Thank you...
