Revit Architecture
Revit Architecture
Valued Mentor
27 Kudos
Post 1 of 3
Revit 2014
525 Views, 2 Replies
09-12-2013 09:45 PM
Hi Guys,
Maybe you could help me with this. When i load my column it follow wall hatching. How im going to remove the hatching from my column.
Please see attached.
Thank you
Hello - I did a little looking and the only way I found for the wall pattern not to cover the column was to change the column family - I unchecked the Automatically joins geometry to walls. Image attached
Now this does prevent from it joining and will give you lines for the column even if you embed it in the wall - so this may not be the best option...
LD
131 Kudos
Post 2 of 3
Re: Revit 2014 - Wall Hatch spread to Column
09-13-2013 05:57 AM in reply to: ennujozlagam
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Valued Mentor
27 Kudos
Post 3 of 3
09-14-2013 08:11 PM in reply to: LisaDrago
Thank you...
