Revit 2014 Update 2 Released
1 REPLY 1
DarrenP
1838 Views, 1 Reply
Direct links:
Revit 2014 Update Release 2
Revit Architecture 2014 Update Release 2
Revit Structure 2014 Update Release 2
Revit MEP 2014 Update Release 2
Revit LT 2014 Update Release 2
DarrenP
1 REPLY 1
DarrenP
in reply to: DarrenP
Improvements made in Update 2 build (20131024_2115):
Autodesk® Revit® Platform 2014 Enhancements
  1. Disables the ability to paste spot elevations into a Sketch mode.
  2. Improves stability when using Results and Compare for Energy Analysis.
  3. Improves stability when exporting to AutoCAD 2000 DWG format.
  4. Improves Online Help experience by properly redirecting help inquiries to Autodesk Help.
  5. Improves stability when enabling Sun Path.
  6. Improves graphic display of Analytical Model Walls.
  7. Improves data integrity of user defined parameters when utilizing temporary view templates.
  8. Improves stability when editing dimensions.
  9. Improves upgrade reliability of projects created with a different language version of Revit.
  10. Improves stability when selecting materials within the Material Browser.
  11. Restores the appearance of area color fills within linked files, when setting the view as By Linked View.
  12. Improves stability when upgrading projects which utilize Keynotes.
  13. Improves stability when importing IFC files.
  14. Improves stability when editing Filters within the Visibility/Graphics Overrides dialog.
  15. Improves stability when saving projects which were upgraded.
  16. Improves stability when combining Phases.
  17. Improves accuracy of Analytical Volumes.
  18. Improves display of Imported Categories for DWG files linked into the project using the "Current View Only" option at time of import.
  19. Improves stability when attempting to turn on sun path while temporary view properties mode is active.
  20. Improves data integrity when export model to FBX.
Autodesk® Revit® Architecture 2014 Enhancements
  1. Improves display of hidden lines on walls in Floor Plan and Elevation views.
Autodesk® Revit® Structure 2014 Enhancements
  1. Improves display of vertical rebar when the rebar extends past the View Range.
  2. Improves the location consistency of Structural beams when upgrading projects.
  3. Improves stability when viewing a sheet which contains Structural Reinforcement Areas.
Autodesk® Revit® MEP 2014 Enhancements
  1. Improves the visual fidelity of point clouds in MEP discipline views in regards to underlay elements in the view.
  2. Improves connection reliability between fittings when upgrading MEP projects.
  3. Improves connection reliability between fittings when changing the size of MEP elements.
  4. Improves the data integrity of the Outside Air per Area value for a HVAC when exported to gbXML.
  5. Removes the "Multiple Values" values for Flow, Velocity and Friction parameters and replaces it with the highest value applied to the entire segment length.
DarrenP
