Revit 2014 shuts dowm after hanging at splash screen
8 REPLIES 8
Message 1 of 9
mhduong
1076 Views, 8 Replies
After installing revit architecture 2014, I could not open it. After hanging at splash screen, the program did have its main screen appeared but then shut down in 1 second.
I have tried everything.  Could not find WSCommcntr2.exe in Task Manager and ENU folder either.
I even tried to uninstall it and go back to 2012 version. However, the installation for 2012 was crashed as well.
Does anyone know about or experience it before? Pls help me!!! ;-((((((
8 REPLIES 8
Message 2 of 9
GHASEM_ARIYANI
in reply to: mhduong
hi
What do you use Windows?
What are your system specifications?
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 9
mhduong
I am using Win 7. I 've attached my computer profile below!
Hope you can help! 🙂
Message 4 of 9
GHASEM_ARIYANI
hi
Please NET Framework 4.5 to check and Upate your graphic Card.
Maybe the problem is resolved.
Message 5 of 9
mhduong
in reply to: GHASEM_ARIYANI
Thank your for your help but it did not work! :-(((
After installing Net Framework 4.5 RC, I restarted my comupter then tried to open revit again but the same problem remains. 😞
Message 6 of 9
edwin.prakoso
Did you manage to activate the product before? I'm aware that there are some issues with activation process.
It closes the program before you can activate it.
You might want to check this: Activation problem for Autodesk 2014 products
If this post solves your problem, please mark it as solved. It will help others with a similar problem to find a solution.
Kind regards,
Edwin Prakoso
LinkedIn | Website | Twitter
Message 7 of 9
mhduong
in reply to: edwin.prakoso
It closed before I can do anything 😞
Message 8 of 9
I'm having the same problem.   Any fixes yet?
Message 9 of 9
I am having a problem on revit 2014 as it start it flashes on screen for 3to 4 second and then it shuts down automatically . please help me out
