After installing revit architecture 2014, I could not open it. After hanging at splash screen, the program did have its main screen appeared but then shut down in 1 second.
I have tried everything. Could not find WSCommcntr2.exe in Task Manager and ENU folder either.
I even tried to uninstall it and go back to 2012 version. However, the installation for 2012 was crashed as well.
Does anyone know about or experience it before? Pls help me!!! ;-((((((
hi
What do you use Windows?
What are your system specifications?
hi
Please NET Framework 4.5 to check and Upate your graphic Card.
Maybe the problem is resolved.
Thank your for your help but it did not work! :-(((
After installing Net Framework 4.5 RC, I restarted my comupter then tried to open revit again but the same problem remains. 😞
Did you manage to activate the product before? I'm aware that there are some issues with activation process.
It closes the program before you can activate it.
You might want to check this: Activation problem for Autodesk 2014 products
I am having a problem on revit 2014 as it start it flashes on screen for 3to 4 second and then it shuts down automatically . please help me out
