Revit 2014 - scheduling families
5 REPLIES 5
hartson9
354 Views, 5 Replies
I am having difficulties with my scheduling list, i have a stone rainscreen family which has 15mm granite and 5mm stone. Everything seemed fine until i looked at the scheduling list and everything in the count column had basically doubled (thinking that these are 2 separate objects). Any help would be greatly appriciated.
5 REPLIES 5
CoreyDaun
in reply to: hartson9
Hello, and welcome to the Discussion Group!
Are the granite and stone aspects modeled separately? In order for them to schedule separately, Revit has to be seeing them as two separate elements. This could happen if a nested Family is designated as Shared, under its "Family Category and Parameters" dialog. If you are still having difficulties, can you attach your Family file here for investigation?
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
hartson9
in reply to: CoreyDaun
Hi, thanks for the reply. Im not entirely sure if im honest, new to this! Please find attached my Stone Rainscreen family.
CoreyDaun
I have loaded this Family into a blank Project and I'm getting correct counts (see image). Try clicking on one line in your Schedule View and then clicking "Highlight in Model" on the Ribbon to see how many elements are selected. (You can see how many elements are currently selected in the bottom right.)
hartson9
When i start a new project i am also getting the right amount in my schedule, however in my current project nothing seems to be working, please see attached images of the rainscreen in model and rainscreen in schedule. Many thanks.
CoreyDaun
Did you try my suggestion in my previous post: Selecting a row in the Schedule and clicking "Highlight in Model"? Unfortunately, I don't think there is any more I can help with without seeing the Project File itself.
