revit 2014 pause/hang up
9 REPLIES 9
Message 1 of 10
mtrblt
643 Views, 9 Replies
revit is hanging up/ pausing for 5-7 secs every 15 secs....really slows progress. it feels like the processor is busy doing something else. os: windows 7 64 bit processor: intel core i7 870 @ 2.93GHz ram: 8 gb video: ATI Radeon HD 5700 series (drives 2 monitors, one for palettes) thanks in advance for your input
9 REPLIES 9
Message 2 of 10
Alaaeldin_Alsahli
in reply to: mtrblt
Do you have Bentley ProjectWise installed on you computer?
If you disable the Antivirus does it make a diffrence?
Keep be me updated
Alaaeldin Alsahli
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Message 3 of 10
mtrblt
in reply to: Alaaeldin_Alsahli
Yes...that appears to solve it.
Any idea what Revit is doing that it's holding up?
I use AVG.
Message 4 of 10
mtrblt
in reply to: mtrblt
And no I don't have Bentley ProjectWise....
Message 5 of 10
Alaaeldin_Alsahli
in reply to: mtrblt
I am not Familiar with AVG but you may have to check if you could add Revit.exe as exception to exclude it from the scaning.
http://www.avg.com/ca-en/faq.num-5190
i found this link. you may need to add these folders
C:\Program Files\Autodesk
C:\Program Files\Common Files\Autodesk Shared
C:\Program Files (x86)\Autodesk
C:\ProgramData\Autodesk
C:\Users\XXXXXXX(you user name)xxxxxxxxxxxxxx\AppData\Roaming\Autodesk
C:\Users\XXXXXXX(you user name)xxxxxxxxxxxxxx\AppData\Local\Autodesk
Alaaeldin Alsahli
Message 6 of 10
Alaaeldin_Alsahli
in reply to: mtrblt
Please keep me posted
Alaaeldin Alsahli
Message 7 of 10
mtrblt
Hi Alaaeldin,
I added the folder exceptions and it seemed like it worked for a while but it's hanging up again.
Temporarily disabling the anti virus software definitely makes a difference, however.
AVG also allows you to applications as exceptions so I'm trying that w/ Revit.exe and a few other autodesk processes and services that I can see in the task manager...I will let you know how it goes.
Other than that, can you reccomend an anti virus program that plays well w/ autodesk stuff?
Thanks!
Message 8 of 10
Alaaeldin_Alsahli
in reply to: mtrblt
Also try to add these as file exception
*.rvt
*.rfa
*.rte
*.dat
*.rws
*.slog
Alaaeldin Alsahli
Message 9 of 10
Alaaeldin_Alsahli
in reply to: mtrblt
The issue with Antivirus, I can't suggest you any because one day you may have to update the antivirus and it may cause an issue with Revit Again.
The best thing is to download a trail and see if it goes well with your system.
At work we are using Microsoft Forfront Endpoint Protection and we have no issues with it.
Alaaeldin Alsahli
Message 10 of 10
mtrblt
Unfortunately file types can't be added as exceptions, only specific files (with specific names & locations).
I'm still using the temporary disable as a workaround....it's ok but not ideal.
*.rvt
*.rfa
*.rte
*.dat
*.rws
*.slog
