Hey Autodesk Community,
Ive been having problems with Revit 2014 on windows 8.1. Ive recently partitioned my macbook pro with retina display and installed windows 8.1 and I noticed that it does not allow me to save any work that I have done. Also the ribbon at the top disappears and have wave my mouse over it to see it. In addition, the bottom right hand corner flickers on and off and I need to use revit for my project thats due in 3 weeks! SOMEONE HELP ME!!!
Solved by BIMologist_. Go to Solution.
Solved by lars-ake.johansson. Go to Solution.
I have Revit 2014 running on Windows 8.1 fine
few things you can do
1. Make sure the latest patch in installed. http://knowledge.autodesk.com/support/revit-products/downloads/caas/downloads/content/revit-architec...
2. Make sure the correct Graphics Driver / Latest on is installed for your Retina . I take there are drivers from Apple too? if not install the nvidia drivers.
3. Try turning off Hardware acceleration in the Options but that has to do with the drawing window and not the interface.
ive tried all those and tried installing the newest patch but this warning keeps appearing. ive attached a picture of the warning box.
what update did you download?
Revit Architecture 2014 Update Release 2
there are 4 revit products each with its own update
DarrenP
I used the Revit 2014 Update Release 2. Im still having the same issues. My save menu wont appear when I try to save my work. After a minute or two it crahses and then I have to reboot my macbook.
okay i followed the instructions on the website and all the problems i had before seem to be fixed, at least so far. Thank you so much for being patient and with me and thank you for all your help!
I also have a big problem with Revit!
I can launch the program without any problems, but if I open any file (or the standard file) i can't use them.
On the left side (in my case) you have the project browser bar, if I try to open an other view it just doesn't load annything. The only thing i see is white.
Only the view that is opened automatically first i can see. And even there i can't do annything. I can't draw a detailline, Ican't make a wall, I can't measure annything and so on...
Just NOTHING workes.
This are my laptop specs:
Dell XPS 15
Windows 8.1
NVIDIA GT 750M (2GB) & Intel HD Graphics 4000 (for powersaving)
16 GB RAM (I know its huge for a laptop)
i7 Intel processor 4th generation.
3200x1800 screen with touch (I also turned resolution down to 1920x1080 but that doesn't help)
As you can see it's suppost to be a very very powerfull laptop. And most of the time it is, but still Revit is a big problem.
Please help me!
By the way I have already tried a lot of things: such as updating/reïnstalling drivers, reïnstalling Revit (2013, 2014 and even 2015, all the same problem).
Problem with Dell M3800 Nvidia K1100M, QHD, 16 Gb ram, two drives, one SSL. Windows 8.1+1. Revit 2015 and Revit 2014 rapidly blinking windows at the bottom. Model dont display in diferent views. I have tried all possible drivers. I use: Nvidia 337.50. First i forced Revit to use only the High Performance Grafic card "Nvidia K1100m". Everything worked out fine. Then I switched back to Intel, as primary grafic card. And the problem was solved. Strange?
Jan Munthe-Kaas
Veteran Autocad 2.6 (1989)----Revit 2015 (2014).
Problem with Dell M3800 Nvidia K1100M, QHD, 16 Gb ram, two drives, one SSL. Windows 8.1+1. Revit 2015 and Revit 2014 /15 rapidly blinking windows at the bottom. Model dont display in diferent views. I have tried all possible drivers. I use: Nvidia 337.50. First i forced Revit to use only the High Performance Grafic card "Nvidia K1100m".
Right click on that shortcut, select the "Run with graphics processor ->" menu, and select "High-performance NVIDIA processor."
..Everything worked out fine. Strange? Jan Munthe-Kaas Veteran Autocad 2.6 (1989)----Revit 2015 (2014).
I have the same problem with nvidia K1100M on windows 8.1 (Revit 2014 and 2015)
Many actions cause the blinking of the user interface. No dialog box open.
I didn't find a solution even if our graphic card is certified on this configuration
Help Autodesk. Help
I found the problem.
In my configuration (nvidia quadro K1100m card + resolution 3200x1800 (recommended), if i use a very high (200% default) height for all element on the desktop the blinking mode of revit 2015 is enabled 🙂
The max height for me is high (150%) --> see attached file
I have the same issue as tobiseun97. Revit 2014 will work on the Windows 7 partition but Revit 2014 and 2015 have the same flickering effect on Windows 8.1 Pro. The laptop is a Dell M3800, graphics Card is a K1100m and the operating system is Windows 8.1 Pro. Painful as the laptop was purchased mainly for Revit.
The problem is most likely the desktop scaling. Revit will have issues with the Ribbon, Quick Acces Toolbar and the Optionbar if the scaling is set to high.
Open “Control Panel\All Control Panel Items\Display”
Change the display scaling to a maximum of 150% (set it to a value between 100% and 150%)
(You might have to check the box “Let me choose one scaling for all my displays” to see that actual value)
There is also another possible issue on some systems (GeForce, Mac Retina).
Even if you turn off hardware acceleration in Revit, the Application frame (Ribbon, QAT) will still run with HA and that can cause issues on some non-workstation graphics.
You can turn off hardware acceleration for the Application frame (but still use it in Revit) by a registry setting.
Attached you will find a zip-file with two registry files:
-> unpack it somewhere on your system.
-> Double click on then file “Disable RibbonHA.reg” and select to import it to your registry.
The file contains one setting that will disable the Microsoft Avalon graphics.
[HKEY_CURRENT_USER\Software\Microsoft\Avalon.Graphics]
"DisableHWAcceleration"=dword:00000001
