Revit Architecture
Revit Architecture
Member
christiaangombert
Message 1 of 15 (3,815 Views)
Revit 2014 on Windows 8.1 32 bit
3815 Views, 14 Replies
02-05-2014 11:48 AM
Hi there,
I'm trying to install Revit 2014 (a student copy) on my laptop. Since the laptop has a older Core 2 Duo cpu, the device is not able to run a 64 bit OS.
This is why I'm running Windows 8.1 Pro 32 bit. I downloaded the installer from the Autodesk website, it's a 32/64 bit installer (Autodesk_Revit_2014_English_Win_32-64bit_dlm).
After extracting the file I try to run the setup. But i get the following errer:
"You cannot install this product on the current operating system."
I searched the forum and most people say that the installer is probably 64 bit and the OS 32 bit, or visa versa. But in my case the installation file clearly says it's 32-64 bit. So it should be compatible whit my OS no mather what.
Some other people suggested i should install .NET framework 3.5, i did but still no succes with installing Revit.
And some other people suggested i should modify the setup.ini file and remove the 'checkOSversion' line from it. I did, and yes Revit did finally install itself on the laptop. But after installation i wasn't able to run the program, it force clossed itself after 1 second.
As you can see i tried many things but nothing worked out for me. Do you guys have any suggestions?
Thanks, Christiaan
Product Support
david.lau
Message 2 of 15 (3,792 Views)
Re: Revit 2014 on Windows 8.1 32 bit
02-05-2014 01:58 PM in reply to: christiaangombert
Technically, we have not certified Revit 2014 on Windows 8.1.  I would try to run the setup.exe in compatibility mode.  It similar to step 4 here:
http://upandready.typepad.com/up_and_ready/2013/07/unsupported-autocad-2014-on-windows-vista.html
You may need to do this as well.
http://upandready.typepad.com/up_and_ready/2013/09/installing-net-35-on-windows-8-with-autodesk-prod...
David Lau
Member
christiaangombert
Message 3 of 15 (3,771 Views)
02-06-2014 01:47 AM in reply to: david.lau
Hi David Lau,
I've tried your suggestions. But I still have the same problems. Installing in Windows 7 compatibility-mode does work, but after the installation i tried to run the program. In windows 8.1 and in windows 7 compatibility-mode the program force-closes.
Also enabeling .NET framework 3.5 didn't do the trick.
Is there anything else I can try?
Product Support
david.lau
Message 4 of 15 (3,754 Views)
02-06-2014 06:22 AM in reply to: christiaangombert
Member
christiaangombert
Message 5 of 15 (3,746 Views)
02-06-2014 08:05 AM in reply to: david.lau
No I have not. It's a GeForce Go 7600. But since Revit 2013 work flawlessly on this machine, that shouldn't be the problem, should it?
Product Support
david.lau
Message 6 of 15 (3,732 Views)
02-06-2014 08:37 AM in reply to: christiaangombert
I have noticed that each year that the software is released, it requires a bit more power in terms of CPU and Video.  It is possible that your current configuration may work with a 2013 product and will not work with a 2014 product.
You may try this if the Geforce card can do it....
http://upandready.typepad.com/up_and_ready/2013/08/fatal-error-autocad-architecture-2014-2012-geforc...
David Lau
Member
christiaangombert
Message 7 of 15 (3,730 Views)
02-06-2014 08:43 AM in reply to: david.lau
Since I only have a GeForce graphics card and no intergraded secondary gpu inside of my cpu, I don't have this chois.
Product Support
david.lau
Message 8 of 15 (3,684 Views)
02-07-2014 02:16 PM in reply to: christiaangombert
I have been informed by the QA team that Revit 2014 only is supported on Windows 8 in 64 bit mode only.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15385625&linkID=21208795
David Lau
Member
christiaangombert
Message 9 of 15 (3,681 Views)
02-07-2014 02:20 PM in reply to: christiaangombert
Well that explains a lot. Thanks for the support anyway.
New Member
kadri.wael
Message 10 of 15 (3,580 Views)
02-23-2014 05:47 PM in reply to: christiaangombert
Hi there,
i have the solution for your problem
if u didnt get solution yet
contact me : kadri.wael@gmail.com
 http://imageshack.com/a/img823/1776/a4sq.jpg
