I've tried installing Revit 2014 on my computer and every time it says some products failed to install. I've turned off the firewall and tried installing it and I still get the same message. The Software Development kit installed, but that's about it. If anyone can help me with this issue you are a freaking life saver! I've posted the installation log file.
Make sure you've got the latest DirectX update, since it says that's what is failing in your log. I had the same problem but it was because I hadn't downloaded my SDK, perhaps try uninstalling and reinstalling again. Good luck with it.
The issue is multiple versions on the same computer.
I had the same problem on a users machine. After doing some web searching found a few posts like this one.
http://synergiscadblog.com/2013/01/16/important-installing-multiple-autocad-products/
I didn't go to all the hoops he has outlined in this post, I just uninstalled 2013, insalled 2014 and then reinstalled 2013 and it resolved my issue.
Hope it resolves yours.
Hi Jlukes27 and welcome to the Autodesk Community!
Thanks for the log file! That shows us that you're experiencing the follow error: Download Failed, Installation aborted, Result=1603
Will you test out this solution to see if it resolves the issue? Thank you!
You might want to try this to: http://forums.autodesk.com/t5/Installation-Licensing/Some-Products-Fail-to-Install-Result-1603/td-p/...
Usually you need to uninstall the prerequisites first. Or you can force the installer to skip installing prerequisites.
Be careful if you are going to try the last one. Make sure all prereq is already installed. However, from the log file I can see you already have them.
