Revit 2014 IFC Exporter plugin - Alternate UI plugin makes it sloooow
0 REPLIES 0
Message 1 of 1
Simon_Weel
332 Views, 0 Replies
Installed the IFC Exporter plugin for Revit 2014 (https://apps.exchange.autodesk.com/RVT/Detail/Index?id=appstore.exchange.autodesk.com:ifcexporterfor... Works OK. Exporting a Revit file of about 200 MB lasts about 12 minutes. But we need to change some settings for the IFC file, so I installed the Alternate UI for the Exporter plugin. Then, using the same settings as before, exporting the same file lasts about 5 HOURS! Anybody experiencing the same issue? Or maybe someone has a solution? Simon
0 REPLIES 0
Rail Community
