Does anyone know in Revit 2014, is it possible to place handrail support brackets perpendicular to the handrail element? I tried turning off "Always vertical" and turning on "Work-Plane based" to no effect. The edited family is based off the out-of-the-box wallmount bracket, which is a level-based family.
What I am trying to do:
What I am getting in Revit:
Many thanks.
Solved by arunag. Go to Solution.
Use a Baluster family template & insert the component you have created. Put dimensions to restrain it based on the offsets you wish to keep.
Load this into project & replace the baluster family to the one created . You can control the spacing too through Railing Edit type properties of Baluster Placement.
Attached a sample of what you had sent (modified the same)
& a similar one present in Library.
Hope what you are looking is the same
