hi
go to Section View And Paste.
thank you for yhour reply but doesnt work.
Many times when this happens (especially with plumbing items) it's because the item is hosted on a floor. While you might have changed the level, it's still being hosted to your 1st story floor. Select the copied item and on the modify tab on the ribbon, select to pick a new host. Select the 3rd story floor and the tub should move to the correct, desired location.
Hi! I am a student and new to here. I have Revit 2014 and have what appears to be an 'unexpected error' (0010.15) has occured when I try to license it. Please can anyone help me? This is extremely urgent and need to get answer ASAP!
hi,
please just copy (cntrl+V) the bath tubs from 1st Floor Level and go to any elevation view (North, South, East, West) and just paste them with "Align to Selected Level" and then click on "3rd Floor Level". I think it will work.
Thanks & regards,
Subhradeep Sen
India
Kolkata
Several of my students are getting the error when they try to open their file that says "Attempt to access the (filename).rvt is passed its end." Any suggestions on why we are getting this error and what can be done to prevent it?
