Revit 2014 - Error messages
6 REPLIES 6
ennujozlagam
880 Views, 6 Replies
I have also experienced some problem, im trying to copy a bath tub from 1st storey to 3rd storey bu using copy and paste to selected level but it copy to 1st storey insted of 3rd storey , what could be the problem. pls find attached.
Thank you for your help,
6 REPLIES 6
hi
go to Section View And Paste.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
thank you for yhour reply but doesnt work.
eccross
in reply to: ennujozlagam
Many times when this happens (especially with plumbing items) it's because the item is hosted on a floor.  While you might have changed the level, it's still being hosted to your 1st story floor.  Select the copied item and on the modify tab on the ribbon, select to pick a new host.  Select the 3rd story floor and the tub should move to the correct, desired location.
Eric Cross
Ewing Cole - CAD/BIM Technician
www.ewingcole.com
in reply to: eccross
Hi! I am a student and new to here. I have Revit 2014 and have what appears to be an 'unexpected error' (0010.15) has occured when I try to license it. Please can anyone help me? This is extremely urgent and need to get answer ASAP!
subhra_civil
hi,
please just copy (cntrl+V) the bath tubs from 1st Floor Level and go to any elevation view (North, South, East, West) and just paste them with "Align to Selected Level" and then click on "3rd Floor Level". I think it will work.
Thanks & regards,
Subhradeep Sen
India
Kolkata
jtaylor01
Several of my students are getting the error when they try to open their file that says "Attempt to access the (filename).rvt  is passed its end."  Any suggestions on why we are getting this error and what can be done to prevent it?
