I'm getting a Revit 2104 Display Error. Here is a screen shot of it:
I'm running it on this type of machine: HP-G71 340US, 8GB RAM, Windows 7 Pro 64-Bit. Although the video card doesn't meet Revits standards, it has run in the past with Revit 2014. This error has come up once before and then it just started to work one day. This error comes up when opening pretty much any file.
Any suggestions?
Solved by jcb77. Go to Solution.
I am having the same error however it crashes Revit 2014 and I lose my work back to the last save point. I did not have this issue with Revit 2013.
i have unchecked hardware accelration the box and am still getting the message. i saw a post about updating the graphics card. which update should i be running for this, if you dont mind me asking.
