I am working on my senior project and I have split my model into two files in an attempt to make the file smaller because Revit continually crashes. I have successfully opened sample files and a classmates model to see if the problem was with Revit or my model. I have tried attatching the files but they are too large, I am hoping to identify the issue with the files so that I can open and work on these to finish the project. Any help would be greatly appreciated.
BTW...I'm running Revit 2014 on MacBook Pro with Parallels 9 but I do not think this is my problem as I have done projects in th past with this same setup and I was able to open and work on other models after experiencing problems with my own model.
