Revit 2014 Crashes at start up due to Device Lock
2 REPLIES 2
yogesh_mundhe
445 Views, 2 Replies
I am facing an issue while launching Revit 2014. As I launch prgram it gives a fatal error. I had noticed this issue arises because of a Device Lock program. If I remove this program it works fine. But as per our policy we can't remove/ disable Device Lock.
Is there any solution to use Revit 2014 program with Device Lock?
Thanks in Advance.
2 REPLIES 2
TravisNave
in reply to: yogesh_mundhe
Clearly DeviceLock is blocking some sort of access that Autodesk needs to launch the program.  It's very possible that you found a security bug that is otherwise unknown without the restriction.  In all honesty, you might have to submit a ticket to either Autodesk, DeviceLock, or both to determine the reasoning.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
After Installation of Updated Device Lock (7.3) this issue have been resolved.
