I wanted to report a bug in Revit 2014.
Section and scopeboxes bug - When i try to split the segment it has no effect?!
To reproduce the problem.
1. Create a scopebox in plan.
2. Create a section in the same plan.
3. Go to the section and with the scopebox you created at 1. associate it to the section view.
4. Go back to plan view, split the section line, move one part of the section.
5. Go to the section view, now move the split section line back and forth and see that the section doesn't update any more.
If you disassociate the Section View from the Scopebox, it starts behaving like normal.
More info on:
http://www.revitforum.org/architecture-general-revit-questions/14169-section-scopeboxes-bug-when-i-t...
