Revit 2014 and Vasari Beta 3 Startup Issue
1 REPLY 1
2233 Views, 1 Reply
recently i have installed revit 2014 and vasari beta 3 in my computer. if i run as administrator, i would show unrecoverable issue and shut down the software. if i run as general user, it is working fine. Since i need use add-ins under revit, it needs admin right. Therefore, i would be appreciate if someone can help to sort it out.
Laura
1 REPLY 1
klaus.schumann
Hi Laura,
Since Vasari is still a Beta product there is no support for it through the normal channel.
You should be able to obtain help with issues related to Vasari through the dedicated Discussion Forum from the main product download page here:
http://autodeskvasari.com/forum
Hope this helps.
Kind regards,
Klaus
Klaus Schumann
Revit Specialist
