Revit 2014 & 2013 - Install on new PCs
6 REPLIES 6
robrds
579 Views, 6 Replies
Hi! We are upgrading our PC's over the next couple of weeks. What are some "best practices" to remove the Revit software from our old PC's and install on the new ones?
Thanks!
Rob
6 REPLIES 6
Jason_S
in reply to: robrds
I just install the software on the new computers and register it.  If you are not going to use the old PC's, I would format the hard drive and be done.
One other suggestion would be to create a Deployment on the server with the Autodesk software wanted.  Then all you have to do is click on that install and let it do its own thing.  Launch the software an select the Create Deployment button.  It will walk you through the process.
robrds
in reply to: Jason_S
Caddman 13 - Thank you for your info.! I appreciate it.
Rob
BIMologist_
in reply to: robrds
I would like to ask, what type on licensing you have 1, Standalone (do you have multi seat standalone(one serial number or single serial numbers?) 2. Network how many PC's? / lics if you have more than a few PCs then the deployment is warranted. 1. If you have stand Alone use License Transfer Utility to port your license to cloud before you uninstall 2, If network then just uninstall
BIMologist / Dr. Revit
Approved Autodesk Services Marketplace provider - BIM Consulting
If you find this reply helpful, please use the Accept Solution or Like button below
robrds
in reply to: BIMologist_
BIMologist1
Thanks for the reply. I have standalone (one serial number) licenses. Its only three seats that we will upgrade PC's with. I was wondering if I would have an issue because the software is installed on the "old PC", the designers laptop, and now I want to install it on the "New PC". I'm not sure how to let the serial number be released from the old pc to install it on the new pc. Thanks again for your help. Rob
BIMologist_
in reply to: robrds
Here is the process http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
robrds
BIMologist1
Thank You! I think this will do the trick. I appreciate your help with it. I will let you know how it works when we do our upgrade (sometime next month)
Thanks again,
Rob
