I did a search for this issue, but I didn't find anything. So forgivfe me if this has been mentioned somewhere else on this forum.
My AutoCAD user is trying to do some 3D rendering in Revit 2014. On the lowest settings, it completes fine. But with any other settings, the rendering process gets to about 95% and then the user gets a BSOD error stating:
"A clock interrupt was not received on a secondary processor within the allocated time interval."
I've updated the screen card drivers and the motherboad BIOS and I have installed the latest Revit 2014 service update.
The machine is has a Core i7 2600 3.8Ghz Sandy Bridge CPU, 8Gb DDR 1600 RAM with a Nvidia Quadro K2000 screen card.
Any help regarding solving this issue will be greatly appreciated.
Solved by Gammaza. Go to Solution.
BSOD are usually hardware related not revit related
read through this: http://www.pcworld.com/article/2026248/can-a-bsod-hurt-my-computer-.html
DarrenP
You don't say. Pardon me if I'm coming down as rude, but that's a really crap answer.
Care to give more details as to which hardware could cause this issue?
The PC runs fine with no issue what so ever while running any of the other applications. The BSOD only comes up when rendering.
You might want to try BlueScreenView, a free, portable program that provides information on your recent crashes.
DarrenP
Is it possible you ran out of RAM? 8Gb isn't what it used to be.
I stopped buying i7's since I used to get a lot of BSoD's too. Xeon's are my preferred chip. 3 times the price - zero BSoD's. My time is worth the extra $750 I spend to save days worth of time throughout the years.
you could also try shutting off one of the processor cores to free up availability for other processes running alongside your rendering.
I've installed a Revit trial verison on a second machine. Exactly the same machine except for a slight difference in the motherboard model, and it worked perfectly.
The motherboard that gave the bsod is a ASUS P8P67-M PRO.
The motherboard that works without issue is a ASUS P8P67 EVO.
So I guess I'll just swap machines around. Thanks for the help.
