Revit 2013 won't work correctly when installed on a Macbook Pro Retina
24 REPLIES 24
Message 1 of 25
3918 Views, 24 Replies
Please could someone help me? I have just bought a Macbook Pro Retina and I have installed Windows 7 Professional using Boot Camp. I then downloaded and installed Revit 2013. When I open a file in Revit, the 2 drop down menu's at the bottom of the page continuously flicker (shown by the arrows on the attached screen shot). Also, the ribbon menu across the top the screen and the menu down the left hand side don't show up (this can also be seen in the screen shot), unless I hover the cursor over the menu.
Please note: I have tried disabling the "Use Hardware Acceleration" option, but this doesn't fix the issue. Also, I have the Update Release 2 installed, which is currently the latest version.
Any help will be greatly appreciated, as I desperately need Revit working for my Uni work.
Thanks very much in advance.
24 REPLIES 24
Message 21 of 25
dzanta
Still sounds lke the Boot Camp or Parallel Desktop software is limiting your RAM usage.  There should be a setting within these apps that will allow you to increase the amount of RAM usage.
You may also double check to verify the graphics card in your laptop is Autodesk compliant to run Revit Architecture 2013
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Message 22 of 25
in reply to: dzanta
I had the very same problem, my solution worked with the resolution.  The hierachy is as follows..
1) Parallels Configuration>Video>Resolution>Scaled
     (This is the main problem I had, if you leave this in the default setting of Best for Retina, in Windows it will always change no matter what personalization setting you chage)
2) Windows>Control Panel>Appearance and Personalization>Text size at smallest
     (Medium or Large did not work for me)
3) WIndows>Control Panel>Appearance and Personalization>Resolution
      (Anythin over 1600x1200 worked for me)
It had to be in this order, or settings kept changing for me.  I use Windows 8 with Revit 2014.
Message 23 of 25
ok, the steps of makink the text smaller makes it work better but there is still a problem of this very small text, any further solutions?
Message 24 of 25
BIMologist_
try this please
http://forums.autodesk.com/t5/Revit-Architecture/REVIT-2014-ON-WINDOWS-8-1/m-p/5130090#M80156
BIMologist / Dr. Revit
Approved Autodesk Services Marketplace provider - BIM Consulting
If you find this reply helpful, please use the Accept Solution or Like button below
Message 25 of 25
Its because your retina screen, you have to set windows on 1920x1200 or less, then it will work properly.
