Revit 2013 will not recognize certified graphics card driver
1 REPLY 1
Melissa.Stewart
596 Views, 1 Reply
Revit Recognizes Dirver version 7, the computer recognizes version 8 and the device manager recognizes version 9.
Windows control the drivers, not Nvidia. The certified driver for this version is 8. Has anyone come across this issue before and if so what was the trick to getting all three on the same page or at least Revit.
Thank yoU!
1 REPLY 1
LisaDrago
in reply to: Melissa.Stewart
Hello - I personally wound not be worried about what Revit says about the graphics card drivers.
If you are having display issues - then I would look into it and possibly turn off the hardware acceleration.
Since not all cards and drivers are tested - I don't pay attention to it.
As long as I have meet the overall requirements - It is good. I get a lot of calls with people in a panic because Revit says their graphics card is bad... It really isn't just has not been tested - two totally different things and I wished that Autodesk never put that in there.
I have not had any issues and my card had never been recognized. Even in the new laptop I just got it states it is a newer driver.. Image attached.
So no real need to worry.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
