Revit 2013 will not open! Triangle Exclamation Error.
2 REPLIES 2
1090 Views, 2 Replies
I just updated my computer with the latest and greatest parts and was excited to open Revit 2013 and try it out. I installed it last night and tried to open it. The splash screen appears for a second and then closes. On the first try, a yellow triangle with an exclamation popped up, it hasn't happened since. I fixed the registry with MS fix it, uninstalled it, and reinstalled it. That didn't fix it.
 I read that it was not compatible with hyperthreading 8 core CPUs. I don't think this is the issue, because I do not have a 8 core CPU.
 I have a i7 3.5 Quad Core with Hyperthreading, 16 gigs RAM, 1 gig Graphics Card, and a Solid State Drive.
Please help!!
2 REPLIES 2
Event Log:
Faulting application name: Revit.exe, version: 2013.0.2012.221, time stamp: 0x4f445896
Faulting module name: mfc100u.dll, version: 10.0.40219.325, time stamp: 0x4df2cfdb
Exception code: 0xc0000005
Fault offset: 0x00000000001b3f41
Faulting process id: 0x11e0
Faulting application start time: 0x01cdb194db40dce8
Faulting application path: C:\Program Files\Autodesk\Revit 2013\Program\Revit.exe
Faulting module path: C:\Windows\system32\mfc100u.dll
Report Id: 1b0c40b3-1d88-11e2-ab86-3085a99594fb
m.ter.stal
I also have that same problem as we speak.
Do you already know what that problem is?. . . What did you do about it.
I have tried an update; reinstall; remove it from my laptop and than regedit and intalled it again, but no effect. same Triangle Exclamation error pops up.
Please, I realy whant to know how to fix it, so i can modeling again.
Greetings from Holland
Maurice
