following the tutorial in ch 6 of "Design Integration Using Autodesk Revit 2013" by Stine,
step 1: create project file , uses the 'commercial' template
but, in the 2013 Revit I just downloaded from the student site, there are templates for 'construction', 'architectural', 'structural', and 'mechanical'
where is 'commercial'?
Solved by granite07. Go to Solution.
Hello - the commercial template was in 2012 - they dropped it in 2013.
I cannot attach it here - its too big.
Email me and I can sent it to you.
LD
it is used in the 2013 tutorial book...
I found it - browse to templates and there is still a copy there in the folder, it is just not displayed in the user interface
