Hİ everyone.I started to learn revit today.But while i creating walls i had a problem.I can't see whole wall. Some lines are missing.How can I solve this problem?
Hi uptheirons, at first go the bottom left corner of Revit, then click on ‘Visual style shaded with edge’ icon and open the drop up menu of ‘Graphic display option’. Now select ‘Shaded’ option from the drop up menu.
Check to make sure you have "Hidden Line" selected.
If so, check your hardware acceleration is on. If it is, try turning it off.
This looks like a graphics glitch of some sort. You may want to try updating your graphics drivers as well.
