Revit 2013 Stairs by Compoenent depth clipping in plan
3 REPLIES 3
612 Views, 3 Replies
I have a fire escape stairs running from the basement to the 4th floor on the exterior of the building.  This is built as one element.
Does anyone know if there is a way to clip the view of this stair so that only a portion of the stair is showing?
For example, I would only like to clip out the stairs in the basement in the 4th floor plan.
3 REPLIES 3
ccollins
You could try using a Plan Region, and set the View Range specifically for your pruposes at the fire escape.
Cliff B. Collins
Registered Architect/BIM Manager
Thalden Boyd Emery Architects
St. Louis, MO
in reply to: ccollins
Tried it, but didn't work...
ccollins
Can you post an image or a stripped down version of the revit file?
Cliff B. Collins
St. Louis, MO
