I have a fire escape stairs running from the basement to the 4th floor on the exterior of the building. This is built as one element.
Does anyone know if there is a way to clip the view of this stair so that only a portion of the stair is showing?
For example, I would only like to clip out the stairs in the basement in the 4th floor plan.
You could try using a Plan Region, and set the View Range specifically for your pruposes at the fire escape.
