2013 Revit ribbon bar is missing commands...
Tried to install the update to fix the ribbon bar - however when I open the update folder on my computer it states
"The update release could not be installed because the expected Autodesk product could not be located on your computer. Make sure that you are using the correct Update Release for the product."
The update file that I am trying to use is called "Autodesk_Revit_2013-x86_Update2.exe"
Anyone?
Make sure you download the correct update for your product. See the list below:
Just curious..
if you cycle through :
Constantin Stroescu
I have had 2 seperate computers where the update did not take. I copied the DLL's from a working updated computer to the problematic computer and all is well. I can't explain why it didn't take as it was recorded as installed properly.
