REVIT 2013 MODIFY EDIT RIBBON INCORRECT
3 REPLIES 3
yilin
3866 Views, 3 Replies
In Revit 2013, when I select an model element, the modify tab ribbon do not show the correct edit features.  For example, when I select the floor, instead of getting the floor edit features, I get the dimension edit features.  I have to cycle thru the ribbons using the little button on the upper right in order to get to show correctly every time I select a different element.
have tried uninstalling & reinstalling the software, opening &  closing revit as well as rebooting my computer.  Nothing works.  Anyone have an idea how to solve this issue?
3 REPLIES 3
edwin.prakoso
in reply to: yilin
Do you have .NET Framework 4.5 installed? Windows 8 and .NET Framework 4.5 are not supported for Revit 2013. But this is fixed in the Update Release.
Have you installed tha latest update of Revit Architecture 2013? The latest is Update Release 3.
You can download the update here.
If this post solves your problem, please mark it as solved. It will help others with a similar problem to find a solution.
Kind regards,
Edwin Prakoso
LinkedIn | Website | Twitter
yilin
in reply to: edwin.prakoso
I use Windows 7 so I don't think thats a problem.  I tried installing the update, but it didn't work.  I think it's because my Revit 2013 is loaded on an alternate D Drive since my C drive is full. 😞 Any work arounds you know of for installing the update?
edwin.prakoso
in reply to: yilin
Windows 7 with .Net Framework 4.5. also has similar problem. Not only Windows 8.
I'm not aware if there's any other way to install an update.
Did you download the correct update? 32bit or 64bit?
Kind regards,
Edwin Prakoso
Rail Community
