Revit 2013 freezes on splash screen
4 REPLIES 4
s3383485
1181 Views, 4 Replies
After hours of searching for an answer i still cannot find one relating to my exact issue.
Im running Revit 2013 on Parallels 8 (Windows 7 x64bit) on a Macbook Pro, it has been working fine for over a year untill today as it freezes on the startup splash screen and the 'SECSplashwnd' becomes non-responsive. Nothing significant has been changed as it was working fine 8 hours ago.
I have tried repairing the Revit installation, restarting windows and mac, uninstalling Microsoft Framework and reinstalling.
Problem Details:
Description:
  A problem caused this program to stop interacting with Windows.
Problem signature:
  Problem Event Name:AppHangB1
  Application Name:Revit.exe
  Application Version:2013.0.2012.716
  Application Timestamp:500439cd
  Hang Signature:652d
  Hang Type:0
  OS Version:6.1.7601.2.1.0.256.1
  Locale ID:1033
  Additional Hang Signature 1:652d4d67ab336aa4de6ac916e5359cdf
  Additional Hang Signature 2:4c04
  Additional Hang Signature 3:4c04b719da4b31c8195176caf8fec7b0
  Additional Hang Signature 4:652d
  Additional Hang Signature 5:652d4d67ab336aa4de6ac916e5359cdf
  Additional Hang Signature 6:4c04
  Additional Hang Signature 7:4c04b719da4b31c8195176caf8fec7b0
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
4 REPLIES 4
rosskirby
in reply to: s3383485
In the task manager, make sure WSCommCntr (or something similar) is not running (end task on it if it is), then try starting Revit again.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
s3383485
The process doesnt exist 😞
I think that only works when revit 2012 doesnt launch.
what else could it be!?
rosskirby
Have you installed all updates to 2013?  Have you installed 2014 recently?  If not, then you may need to reinstall .NET 4.0.
If that doesn't work, you may need to go in and edit the registry.  Google "Revit 2013 hangs at splash screen" and "parallels" and you should find a few forum topics covering how to resolve this.
Ross Kirby
Principal
Dynamik Design
s3383485
Couldn't find an answer 😞 just had to use a timemachine backup and copy over the Window 7 virtual machine image from a prior backup.. seems to work fine now despite the inconvenience.
