Revit 2013 doesn't launch
8 REPLIES 8
Message 1 of 9
tstewart
327 Views, 8 Replies
Bldg Design Suite 2013 was installed correctly and now, Revit loads  but doesn't launch. It flashes as if it will start and closes.
HELP!
Tags (1)
8 REPLIES 8
Message 2 of 9
David_W_Koch
in reply to: tstewart
You might be experiencing a corrupt CascadeInfo.cas file.  See http://usa.autodesk.com/getdoc/id=TS13894457 for more information and the fix.  The technical solution was written for 2010 products, but I have seen this in later releases.  If that is not the problem, you might try searching for crash on startup for Revit in the Knowledge Base.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
Message 3 of 9
tstewart
in reply to: David_W_Koch
Thank you and my version is a standalone and not network. Does that matter?
Thaddeus M. Stewart, AIA
Managing Principal
Integrated Design & Construction
60 Connolly Pkwy., Bldg. #11B, Suite #110
Hamden, CT 06514-2519
203.909.6559 (o), 203.507.2137 (f)
www.idandc.nettstewart@idandc.net
Message 4 of 9
Jose.conde
Check if you have Panda Antivirus Running, there is a patch if this is the case.
Regards
Jose Conde
Consultor AEC Autodesk
Building Solutions Division
(+598) 99 154678
Montevideo, Uruguay
Message 5 of 9
David_W_Koch
Per the technical solution, that only applies to network licensed software.
David Koch
Blog | LinkedIn
Message 6 of 9
Jose.conde
I have had problems with stand alone version in my own compiuters
Jose Conde
(+598) 99 154678
Montevideo, Uruguay
Message 7 of 9
tstewart
in reply to: Jose.conde
How did you resolve them?
Sent via the Samsung Galaxy S™ II Skyrocket™, an AT&T 4G LTE smartphone.
Message 8 of 9
Jose.conde
http://soporte.pandasecurity.com/foro/viewtopic.php?f=37&t=618
Check this out, maybe there is a new version for 2014 products,
Regards
Jose Conde
(+598) 99 154678
Montevideo, Uruguay
Message 9 of 9
tstewart
I'm working on 2013 currently.
