I have a problem with Revit 2013 crashing after I use it for a couple of minutes. The message reads "Autodesk Revit has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available." I don't seem to have the issue with Revit 2012.
Any ideas to check out?
Welcome to the discussion!
First thing I would check is do you have all the service packs installed?
LD
Does a window pop up to report it to Autodesk?
If so - have you sent it in? It is important and they really do read them. A detailed description is always best.
Is it the same file? Or different files?
Have you tried using the file on a different computer?
Have you run an Audit on the file?
I know it is a lot of questions - but just trying to narrow it down a bit.
LD
