Revit 2013 Crashes at splash screen
4 REPLIES 4
brechtel
3941 Views, 4 Replies
This just started happening. I can't isolate what is causing the issue. I tried ot repair installation - no success. A clean uninstall/install, no success.  Online fixes for similar crashes in 2012 unsucessful.
Any other ideas out there?
Problem signature:
  Problem Event Name:APPCRASH
  Application Name:Revit.exe
  Application Version:2013.0.2012.221
  Application Timestamp:4f445896
  Fault Module Name: DesktopMFC.dll
  Fault Module Version:2013.0.2012.221
  Fault Module Timestamp:4f445880
  Exception Code:c0000005
  Exception Offset:000000000010d51f
  OS Version:6.1.7601.2.1.0.256.48
  Locale ID:1033
  Additional Information 1:6930
  Additional Information 2:6930e14a37ab2a885ac6e8cf50158837
  Additional Information 3:e566
  Additional Information 4:e5662ffe606fd9ea7b8007d482ed1df3
Read our privacy statement online:
  http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
  C:\Windows\system32\en-US\erofflps.txt
4 REPLIES 4
ryan.duell
in reply to: brechtel
I would recommend first uninstalling \ reinstalling Microsoft .NET 4.0.  You can use the link below to reinstall .NET after you remove it:
Microsoft .NET Framework 4 Client Profile (Web Installer)
.NET 4.0 Update:
Update 4.0.3 for Microsoft .NET Framework 4 – Runtime Update (KB2600211)
Ryan Duell
seastrunk
I have this same problem, but have never had Revit 2013 even open though all other Autodesk suite programs do open.
Were you able to fix this problem and if so what worked?
Thank you,
sadelphin
in reply to: seastrunk
Look for WSCommCntr3.exe process in the task manager, kill it and try to open. And try this one, how-to-fix-when-revit-archstruct-2012
Recently I had both my Revit MEP 2012, RAC 2012 and Revit 2013 one box stop working. All of them would crash at the splash screen. Clean uninstall / re-install did nothing. Per Ryan's suggestion I went into Control Panel and repaired Microsoft .NET Framework 4.5. This fixed all versions.
Thanks for the suggestion.
