I just downloaded 2013 and it keep crashing when i try to make floors in my building.
I had version 2011 and it worked fine on the same laptop, so i wonder if 2013 works with another graffic card?
HELP please;-)
Have you installed the service packs?
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9273944#section1
I have not had this issue and i work only off of a laptop. I would start with the service pack if you have not already done so.
LD
I had the same problem and try a lot, reinstalled many times.
The solution was to replace my computer by a new on with
4 core i7 processessors
16 Gi ram
SSD disk 360 Gi +- and 720 Gi - 7200 rpm
nVidia graphic card, 2Gi ram.
And a lot of money to paid.
Good luck!
It's a bug in the program solved with the service pack. I had the same problem with the cloud contour and after service pack 1 didn't have it again.
Thanks, alex
