Here is the end of the journal file:
'*********************************************************** 'CT [Modifier la nomenclature ou les quantités]: ' {1} Dialog_Revit_ScheduleBar_a ' {458} Dialog_Revit_ScheduleBar_b ' {458} Dialog_Revit_ScheduleBar_c ' {458} Dialog_Revit_ScheduleBar_d ' {458} Dialog_Revit_ScheduleBar_e ' 'Cache: ' '*********************************************************** '<<End build CT>> ' 0:< View Open: Element expansion used 0.026257 seconds averaging 0.000102 seconds/hit for 258 hits. ' 0:< View Open: Element expansion used 0.000000 seconds averaging 0.000000 seconds/hit for 0 hits. ' 0:< Exception occurred 'C 27-Mar-2013 10:49:18.033; 0:< ExceptionCode=0xc015000f ExceptionFlags=0x00000000 ExceptionAddress=0000000077B1DF0C ' 0:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ] ' 0:< RAM Statistics: 12640 / 16311 630=InUse 634=Peak ' 0:< VM Statistics: 8386798 / 8388607 539=InUse 543=Peak ' 0:< 0000000044925340 CompactMemoryManager Memory Statistics: 4 MB with 2 MB view ' 0:< 0000000044925440 CompactMemoryManager Memory Statistics: 4 MB with 2 MB view ' 0:< 0000000044925540 CompactMemoryManager Memory Statistics: 4 MB with 2 MB view ' 0:< 0000000044925640 CompactMemoryManager Memory Statistics: 4 MB with 2 MB view ' 0:< 0000000044925740 CompactMemoryManager Memory Statistics: 4 MB with 2 MB view ' 0:< 0000000044925840 CompactMemoryManager Memory Statistics: 4 MB with 2 MB view ' 0:< 0000000044925940 CompactMemoryManager Memory Statistics: 4 MB with 2 MB view ' 0:< 0000000044925A40 CompactMemoryManager Memory Statistics: 2 MB with 2 MB view ' 0:< Before : Destroy Display Manager ' 0:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ] ' 0:< RAM Statistics: 12641 / 16311 630=InUse 634=Peak ' 0:< VM Statistics: 8386798 / 8388607 539=InUse 543=Peak ' 0:< After : Destroy Display Manager ' 0:< System (MB) [Available / Total ] [Revit Memory Usage (MB) ] ' 0:< RAM Statistics: 12642 / 16311 630=InUse 634=Peak ' 0:< VM Statistics: 8386798 / 8388607 539=InUse 543=Peak ' 1:< DBG_INFO: Detected unfrozen change of selection.: line 595 of n:\build\2013_ship_x64_inst_20121003_2115\source\revit\revitui\modscope\ModScope.cpp. ' 0:< ::125:: Delta VM: Avail +17 -> 8386816 MB, Used +0 -> 539 MB; RAM: Avail -2 -> 12640 MB, Used 628 MB ' 0:< DBG_INFO: AfxMessageBox is not converted to Task Dialog.: line 1164 of n:\build\2013_ship_x64_inst_20121003_2115\source\revit\desktopmfc\mfc\DesktopCRS.cpp. ' 0:< MessageBox "Une erreur fatale s'est produite. L'application va être fermée. Vous avez la possibilité d'enregistrer des fichiers de récupération pour tous les projets que vous avez modifiés. ' 'Voulez-vous enregistrer un fichier de récupération?" ' 0:< ::125:: Delta VM: Avail -20 -> 8386796 MB, Used 539 MB; RAM: Avail 12640 MB, Used +0 -> 629 MB 'E 27-Mar-2013 10:49:21.019; 0:< Jrn.AddInEvent "AddInJournaling" , "MessageBox(YesNo,Revit).Click(No)" 'H 27-Mar-2013 10:49:21.042; 0:< Jrn.Data "MessageBox" _ , "IDNO", "Une erreur fatale s'est produite. L'application va être fermée. Vous avez la possibilité d'enregistrer des fichiers de récupération pour tous les projets que vous avez modifiés. " & vbLf & "" & vbLf & "Voulez-vous enregistrer un fichier de récupération?" 'E 27-Mar-2013 10:49:21.042; 0:< ' [Jrn.AutoConvertedMessageBox] Rvt.Attr.MessageId: IDS_UNRECOVERABLE_ERROR Rvt.Attr.MessageAnswer: IDNO
Detected unfrozen change of selection. I don't know what it means.
Would it be possible to send us a copy of the project, so that we can research this error? If yes, please send me an email and I will give you details on how to upload the file(s).
Anna (anna.oscarson@autodesk.com)
